desert sailor
- Jun 22, 2008
- 2
Hi guys, I put in new fuel, cleaned the carb, toyed with the mixture needle (started at 1.75 to 3 turns out, from in snug), checked the fuel pump, there is weak but consistant spark at the plugs, and the new plugs are slightly damp when I pull them out. I'm thinking it may be the ignition coil, as it won't even fire if I starter fluid the cylinder and then put in the plugs. There is fuel sitting in the intake after cranking it over many times. (maybe I'm to rich... that would be a first). Ser.# is 10061-66. I don't know how to tell what year that is. She was runnin' fine and just died. Thank you for any advice
