Got the motor very cheap knowing it had problems....
Was told the splines in the the prop must be badly worn as it was loose - changed the shear pin and thats fine now, no splines to wear!
Cleaned carb and it starts first pull every time, runs smooth and quiet.
Water in the oil was problem 3, looking on this forum told me it could be the plastic oil filler assembly that mine has, so had to pull motor off to change it.
Removed all the bits I think need to come off, carb off out of the way, wiring disconnected, dropped gearbox, took out 4 bolts from leg up into motor but cant move it, feels like its still bolted in...
I cant see any more bolts, but it sure feels like there must be one or two!
Serial number is B100 1014396
Help.
Help.
