AY impeller
coolbri70
looking to get an impeller for my motor there are 2 listed 1 is called AY impeller and cost more, what is the difference:confused:
coolbri70
Re: AY impeller
the model #85995R i was looking they look the same:confused: the AY Impeller did mention a 12 month warranty
Daviet
Re: AY impeller
It's the same part number, where did you get the "AY"?
coolbri70
Re: AY impeller
it is cheaper, they all have different prices, are some better:confused: last longer?
Daviet
Re: AY impeller
They are showing 3 of the OEM impellers (389289) in stock, that's the one I would get.
coolbri70
Re: AY impeller
or should i get a pump kit, what all will i need to do this job:confused: gaskets??
Daviet
Re: AY impeller
It looks like your pump uses a s/s liner in it, unless the liner is damaged, I would just install the impeller.
coolbri70
Re: AY impeller
thank you:D you have been quite helpful , i havn't changed it yet, it runs good, pees good, i had to order a different piece that wasn't enough to make an order, so i thought i would order this too before it goes bad
Daviet
Re: AY impeller
You're welcome, good luck with the impeller replacement.
