Automotive equivalent for a Mercruiser cooling system hose?
Augoose
This is for a '89 4.3 - I'm looking for item # 32-87108, "hose, thermostat" and goes from the water pump to the thermostat on the starboard side of the engine. It looks like this....
Anyone know of an automotive equivalent? A trip to Oreily's and walking down the hose section didn't produce much. Was trying to find one locally, but if not then I'll order one from the marine store here on iboats.
Thanks!
Augoose
Re: Automotive equivalent for a Mercruiser cooling system hose?
im guessing you already checked i boats????
Yes I did - please read my initial thread.
i know you asked for a car part but most cars dont use special hoses designed for a boat vice versa
Randy - FYI, my Mercruiser (and many others) are GM engines, which means there may be automotive crossovers. Since a marine engine cycles either fresh water or coolant, I'm interested to hear how a marine hose could possibly be different from a hose for an automobile, other than the price of course.
Just because it's on a boat, doesn't mean that an auto application won't work. What do you think the hydraulic trim runs on? Guess what, it's Auto trans fluid. Does your boat have an automatic transmission?
Gary H NC
An auto hose will work just fine if you find one with the right curve and bend to it.
Check Napa if you have one in your area.They do have a marine book and some parts on their computer.
Oriely's is a bunch of idiots in my area.
Augoose
Thanks Gary. I figured there wouldn't be an issue using an automotive hose, its just finding one!
LOL about Oriely's - same issue here. I'll try Napa or AdvanceAuto
Gary H NC
Worst comes to worse that is OMC or BRP part number 0312781,any BRP-Johnson-Evinrude dealer can get it.
0312781
That Merc hose listed above should work too...
Napa and Sierra marine are the same part numbers too.
captk
The thermostat hsg is unique to Merc. that being a molded hose you probably wont find an automotive that will work.
Randy J
okeydokie ben there don that last year i have a 89 corsica 175 SunBird with a 4.3 OMC wwCobra Stern Drive pulled the engine out and redone fly wheel as teeth had a few bad spots, well got the teeth ring from auto zone and took to machine shop to have R&R..but the hoses i got from boat dealer replaced all of them, exhaust etc just the teeth ring and alt & water pump belts all they had avail.. and exhaust flappers that was a order from boat dealer and those are getting hard to get.. i understand where your comming from ..but there some parts we all need on used boats that are not availble anymore too.. well git er done springs comming :)
proshadetree
Randy J Do not use automotive ignition or charging on a boat. Unless the thing has an open engine compartment. Makes a lake bomb with a unknown fuse. Automotive hose is great on the fuel system until someone surveys the boat and knocks you on it. Or you sell it and it ruptures and the new owner sues you. Cooling system will probably be ok but why risk it?
Randy J
jsut spark plugs 2 v belts and starter flywheel teeth ring all i got from auto parts store all else is 100% OMC parts on boat thats why i said teeth gear ring from auto zone as cant get a new flywheel for a 4.3 from OMC the ring gear is heated at shop took off the flywheel and new ring gear pressed back on flywheel that was to help any one else that may need a new flywheel cause of teeth damage... thats another storey as my uncle kept on and on starting my boat while i was gone to get a new battery 45 miles away got back with new then found out what he did..well that concluded that day at lake ...yea i still let him go fishing boating with me but i keep a eagle eye on him ...
4js
Was any of that English? I only understood about 10% of that...
Ayuh,... It'll be tough to find an automotive hose like That 1....
Most cars have a Radiator between where that hose starts, 'n where that hose ends.... :rolleyes:
dccordell
Not changing the subject, but to Randy on the flywheel teeth, I have in the past used a cut-off wheel on a grinder to cut the old flywheel ring off (one cut anywhere will break it loose), then put the new ring in the oven for a while to heat it up and let it expand, then grab it with some pliers and take it to the flywheel and pop it on real quick while it's real hot. All you need is the few thousandths of an inch to get it on, which you get from the oven heat. Just have to sneak it past the lady!
To the OP, you might could try to check a local salvage yard if you're lucky enough to have one around your area. Or ebay? Might get lucky... Good luck.
Augoose
Well I stand corrected - Oreily's did have the hose I was looking for. Apparently they have a marine cross reference and located it by the part number.
Thanks all for the assistance
betayv
go to napa and get a flex hose they have the correct diamater and lenght...
Don S
Why ???? He found the right hose.
Randy J
yeaa=!!!! now maybe augoose can help us all in wish power for the weather to hurry and get boat season here huh???? cabin fever no fun lolo
Don S
Huh???
Have you tried re-reading any of your posts before posting?
I make a lot of spelling and grammatical errors, but some of your replies are almost impossible to figure out what you are trying to say.
Augoose
All,
I meant to do post this earlier - for anyone in the same boat (no pun intended), the O'reilly part number for the hose is 21801.
link - http://www.oreillyauto.com/site/c/detail/GAT0/21801.oap?keyword=21801
Thanks again for the help. And yes Randy J, I've got a case of spring fever as well. It was 68 here last week and my lower unit was still sitting on the workbench........
Augoose
Thanks Betayv - I tried a couple of different flex hoses, but in order to get the angle the hose became pretty long and looped out quite a bit. It probably would have worked fine if not for the sharp 90 degree turn the original had to make. I'm glad I found the stock hose though - I was really hoping that I could pick one up locally.
