Discovered my other engines were 351M's so couldn't use them.....abandoned the project until about mid June when I decided to get on my 36" (not 4') snipe again...... well it moved!
It had been soaking in about 25 litres of an ATF/Diesel mix (to top of dipstick tube) for 3 weeks.
Well great, so I reset my snipe for another 1/8th turn and so on. Thought I had I solved until it jammed again, so I applied more torque and broke the casting hub of the balancer at the same time that I managed to cam over the resistance. I was then able to move the engine with a ratchet and socket. It did become quite free and I could turn it over with the starter.
Drained all the old fluids from block and filter. Refilled with just straight oily diesel and ran starter a bit to circulate. Heard some clacking so I removed the valve cover. Freed two sticky valves and removed a pretzelled push rod....haha, remember this was just to be entertainment before removal.
Still had that old 188 block laying under a tree .....correct balancer and proper push rod. Installed my new parts and had no more noises!. Rotated her on the starter, oily diesel was coming over the rockers and all seemed well. Put the covers back on, completely drained to drip dry. Then added new motor oil and a filter. Rolled it over some more for good lube.
Had to go through some pain to make sure distributer cap, wires and plugs were all correct and ready to fire. Filled the float bowl but it just wouldn't fire. Finally after dumping a lot of fuel directly in and furiously pumping the throttle it blasted to life. Almost full throttle, funny car flames, right out the heads before it stalled.
There I was in my driveway within a MASSIVE cloud of smoke caused by burned penetrating oil, ATF, diesel. etc.
Caught it on the second try and was able to maintain control through a short test of different revs right down to idle.
I shut it off after 45 seconds or so.
Next evening after work it fired up immediately and ran smooth. Today I tried again, sounds good enough to me..... going to bolt the exhaust manifolds on and add water next..... maybe tomorrow.
Not quite ready to remove that old 302 just yet. Regards.
