2000 johnson 50 hp, has auto tilt. I'm used to an older engine youy manually lift. My concern is the fact that I boat in one of the rockiest areas on the east coast, and while I know all the reef, there is always the possibility of hitting a rock at low tide. With the manual lift (assuming the motor was not locked down) the engine would rotate out of the water. What happens when you have an auto lift system and you hit a rock?
Also, what type of maintenance is required for a hydraulic lift system??
thanks !!
thanks !!
