Auto Choke
rooskie03
Can somebody tell me how I can test to see where my electric (auto) choke is not working.
Bradster941
Re: Auto Choke
Rooski03, out boards don't have auto chokes.<br />Generaly, you push in the key while starting the engine. Some control units have a toggle switch.<br /> There are 2 types of chokes. One closes a set of butterfies over the intake on the carbs.. This cause a high negative pressure pulling in additional fuel through the carbs. <br />But the more common methode is a seperate injector pump that when ingaged adds extra fuel in the starting position.<br /><br />It would help to know what engine you have. Model serial numbers, etc. :)
OBJ
Re: Auto Choke
Well....some of the older engines did have an auto choke....<br /><br />Rooskie....please post year and HP of engine. If ya' don't know the year....post the model number. Thanks.
rooskie03
Re: Auto Choke
Sorry about that, forgot to post the info.<br /><br />It's a 1975 Johnson 115hp v-4, it does have a toggle switch by the key.
OBJ
Re: Auto Choke
Rooskie....remove the engine hood. Turn the key to on (just to on) and lift up on the choke toggle and observe the choke plates on the carbs. If the choke plates close, your good to go.
