Ive read a bit about SeaFoam on this forum for decarbing Johnson motors is this available in australia under the same name or is there a comparable product available thatis as good as SeaFoam.
promotec,<br />You could contact Seafoam with this question at customerservice@seafoamsales.com<br /><br />At the same time, you might ask if they have a dealer that ships to Australia.<br /><br />I understand OMC Engine Tuner and Mercury Power Tune are comparable products but I don't know about their Australian availability.
Promotec, Chris will be able to advise as to what is available downunder, you can get his attension in the merc forum. I know there are plenty of brands - I don't know which ones are suitable for 2 strokes. <br /><br />I use a bulk brand (not available in retail outlets) called 'Chem-Tune 3000'.<br /><br />Aldo
Promotec, I use OMC/Bombardier Engine Tuner, available at any OMC/Bombardier outlet, seems to do a pretty good job, lots of gunk out the thru-hub exhaust after using and better performance also.<br /><br />Cheers
