Hi Guys<br /><br />the honda is booked in later in the week at the dealers. I took it out today and tried to eliminate a few things. firstly this motor idles in neutral at about 1020 rpm (Small spark plug tacho from honda). At this rpm it is ok. If i park this motor and fish for a while and then turn it on it will start but the rpm has dropped about 150-200 rpm. This is why it might stall when it put in gear. It can take at least a minute to smooth out and climb to 1000 in neutral? Is this normal for Hondas<br /><br />i tried disconnecting the fuel line and letting the motor run for a few minutes to drop float levels before turning it off and fishing in case the float level was too high and fuel was expanding and overflowing into the cylinder. It started ok but the idle began at 820 and slowly sorted itself out and reached 1020 rpm after about a minute. This may put an end to the float level theory.<br /><br />If i fished with the cowling off the motor started perfectly and started at 1020 -1100 rpm. It was smooth with no coughs/ splutters.<br /><br />If i quickly turn the motor off and on it starts perfectly as well.<br /><br />It seems to me to be heat related or air temp related under the cowling. Any suggestions to give tho the mechanic would be appreciated.<br /><br />Regards<br /><br />Kellaig
