I found this in one of your posts...<br /><br />hello<br />yes it looks similar only about 3 feet long and no splines<br />one OD for the coupler and one OD for the gimbal bearing<br />I will get it tonight<br />looks like this storm coming is gonna be a big one. if it hits it will make a mess here.<br />well start with a piece of solid stock 1.375 diameter. turn it back 2.145" at a diameter of 1.008" the next OD will turn back another 2.765" at 1.153" the overall length of the tool is aproximatly 26". you may wish to add a 1/4 in lengthh to the first linear diminsion. the newer v8 couplers have grease fittings that hit the first shoulder. the first OD fits the shaft coupler and the second fits the gimbal bearing.<br />good luck <br /><br /><br />I was going to see if I caould have a tool made for myself... but I see the specs you supply and what this aglinment tool looks like, and your specs seems to not have the same OD?? <br /><br />MERC TOOL <br /><br />i am just courious why
<br /><br />kid
