Attn. Joe Reeves and GT15070
ScottSabre72
New jets finally arrived. I put them in tonight, put the carbs back on and ran it with the muffs on in the side yard. I ran the motor out of gear of course up 5000 RPM! I think it is fixed, only went to 4200 in or out of the water before. Big difference in hole size between the old and new jets. Mechanic at shop said it isn't true but you could see a difference and verified with a toothpick, I showed him this. I will run it this weekend and check the timing. You guys are awesome. Thank you very much for your info. <br /> :D
ScottSabre72
Re: Attn. Joe Reeves and GT15070
I took it out on the water tonight and set the base timing. Holy sh#t, like a new motor with twice the power. It jumps up and goes now. WOT gets up to 4950 RPM loaded. Won't idle good but I will start a new post for that. Thanks again!
