Attention MacGregor sailboat.owners...
White90GT
A 1999 25' MacGregor was just donated to our sea scout crew and the trailer has some rust and bunk issues. I need some pictures of the trailers that came with these boats so we can figure out what to do with the bunks. The current bunks are v shaped instead of long ways with the boat and it just does not seem right to have this much weight supported by a couple of boards in the back and middle of the boat.
centerline
there really is nothing mush to see other than bunk boards like any other swing keel boat.. or water ballasted boat.
I have the original trailer, as originally set up by macgregor under my 25 (except for the re-positioned axle), and there is nothing complex or scientific about it. very simple.
there is a cross member in the trailer almost directly below the front edge of the forward window.. the trailer frame ends about a foot behind where the cabin trunk meets the cockpit... so another cross member there.
the front x members have 3"high risers from it, 20" out from centerline of the trailer... the rear xmember has 10" risers (to allow for the keel), but you could get by with 7.5 or 8 though.. these are also 10" out from centerline.
there are over sized holes drilled in the top of the risers, and angle irons with over sized holes in them also (these points mate together and allows for some adjustment of the bunk angle as it fits to the boat)....
then a carpeted 2x6 is bolted to the top of the angle irons.... on each side.
in time, the weight of the boat will form the boards to the hull...
macgregor had the axle under the 25's, much too far forward.
when the boat is loaded "normally" with the gear we usually carry for daysailing, it can cause minor swaying in the tow vehicle. you will need to move and keep all the loaded gear into the v-berth to keep some tongue weight.
if you are going to load the boat for cruising, the axle will definitely have to be moved rearward.
with the axle under the trailer and positioned just a few inches forward of the rear part of the rear window is a perfect balance no matter how the boat is loaded.
the Mac 25's are nice comfortable boats to cruise, sail and relax in when they are set up right... good luck
White90GT
Just now saw your reply, haven't been on Iboats for a while. We rebuilt the trailer, lengthened the tongue and moved the boat forward a little bit to add some tongue weight. I have it set around 200 lbs of tongue weight now with no extra weight in the boat. Seemed to pull well for a short pull, but we haven't hauled it anywhere far yet. We are thinking of taking it to Canyon lake this summer which is a couple hundred miles away.
We switched from the V bunk style to long bunks from the front V bunk to the rear and it loaded pretty easily.
MOD EDIT - Removed selling info.
