Attention Evinrude Experts!!! help needed
wikelam
I have a 50hp evinrude lark, Ser#e004565 mod#50473m. i was told that this is a 1974 model but i thought that the model# told the date. 50 is horse power and 73 is the year. what is the correct year. <br /><br />Also i have an older evirude 40hp??(was told by seller). ser#02220 mod#35531m what is the correct hp and year?<br /><br />On the older motor i do not have the wiring harness so i can not hook a key up to it to start it. i know it needs a solenoid but do not know which wires will go to the solenoid and which ones go to the key switch. i have a wiring diagram for a motor close to it but would like to know for sure!! the harness that is on the engine has the following---><br /><br />. -----------<br /> |--- Y T Bl ---|<br /> | Bk R W N Bk |<br /> |-------------|<br /><br />Y-yellow<br />T-Tan<br />Bl-blue<br />Bk-black<br />R-red<br />W-white<br />N-No wire connected<br /><br />these are the wires in the plug from an end view, colors are faded so not sure on white an tan.
Bear
Re: Attention Evinrude Experts!!! help needed
35531 Evinrude 1962 40 hp<br /> picture
wikelam
thanks, that helps in ordering parts. any help on the wires. or 50 hp
Bear
50473 Evinrude 1974 50 hp
wikelam
Whats up with the 73. is this how you tell anyway? or was it manufactured in 73, and sold as a 74?? just curious. was told it was a 74 by a few people so i believe it is a 74 now. thanks.
papasage
if you go by the wiring diagram that i gave you the 40 will work fine . the 50 may have a switch probablem . check the wire on it . i changed the switch and havent run it . till you picked it up . did you git my email the other day . havent herd frome you . papasage
wikelam
thanks for all help.
