Does anyone have drawing or a website that talks about positioning the kicker motor. I need to know how high and how far from my outdrive I should mount my kicker. help
I just mounted a 15 hp on the back of my sailboat transom.(A)Swing your motor mount into full down position, measure the distance from the top of the motor mount to the water surface (B)Measure the distance from the motor clamps to a spot roughly 6" above the water intake holes on the lower end. You want those holes under the water,right? That distance should be the same as the distance in (A)
