Re: Atf in coolant?
If your radiator has a transmission cooler integrated into it, then the coolant core and the ATF core have leaked into each other, ATF in your coolant is the least of your problems... the coolant in your ATF should scare the crap out of you.... STOP DRIVING it NOW. The radiator will need to be replaced and both the cooling system and the transmission will need a flushing, I'd do it twice.<br /><br />If you aren't comfortable doing it, take it in and prepare to pay.
