At last, my TN-26 is restored! (pics)
TN-25
I just had to share. I just picked up my 1950 Johnson 5-horse from North York Marine (nymarine.ca) 15 months after dropping it off for a total restoration. The original powerhead had too much clearance between the crank journals and the bronze bushings, so Peter found a TN-28 block that was a better basis for a rebuild. The TN-28 block also used more modern points and other tune-up parts. While finishing up the motor he found that my ready-pull starter would not fit on the new block because the TN-28 block used a different flywheel. He found another ready-pull but had to strip it and repaint it, plus the rope and starter spring needed replacing.
When I dropped it off it was a worn-out motor that dad retired in 1965 and replaced with a 9? Johnson. It had only run once since 1965 when a cousin borrowed it in 1976.
Here are some pictures of it, plus a shot of the cedar-strip square-stern canoe that it will end up on (that one will take a lot of elbow grease, blood, sweat and tears.) The canoe will be my next endeavor that will have me posting in the Boat Restoration forum. I must be a masochist.
chuckles
Re: At last, my TN-26 is restored! (pics)
Nice Job !
I'm Working On A 16 Ft Grand Laker Canoe And Do Need Some Input On My Transom Repair If Anyone Cares To ?
I Have Dry rot In The Glue Joints On A Oak Transom. What Will Be The
Best Solution , ( Router Then Wood Strips ), Or Some Kind Of Fiber Filler With Reinforced Glass And Resin ?
Thanks Chuckles
jbjennings
Wow! Very nice motor. I LOVE that boat. It will be just beautiful on that boat. Heck, it doesn't even look like the boat needs restoring.
Thanks for the pics,
JBJ
BKS72
Nice work! That is a sweet looking mill.
D
DJ
Guest
Absolutely beautiful. Nice boat too.
samo_ott
Peter did a good job!
wbeaton
We need some action photos/video! Beautiful resto.
