Re: at high rpm engine misses and breaks up
Hi Inkman, see that your a fellow Buckeye. Does your engine still have points or electronic. If it is points type ignition, the wrong gap/dwell can cause the missing a sputtering. But check your fuel filters also. A fuel restriction can cause problems of leaning out at high RPM which is not good on the ole power plant. Have you ever been on the Muskingum? Trying to find someone that has. Planning to take a trip on it next year. Good Luck
