Augoose
- Mar 21, 2010
- 1,245
All,
Would I be OK mounting the transducer as show in the attached photo- just to the right of the drain? Its a small humminbird transducer and according to their instructions they state that as long as it is 15" away from the prop it should be ok. However, in their manual illustration they show it 15" to the side, not in front of the prop like in my plan. From the prop, it seems my potential mounting location would be well over 15".
The reason I want to run it there is so that I can run the cable for the transducer along side of the pitot tube without having to drill new holes - and so that I can use the same transom hole as well.
I've read that mounting a transducer in front of the prop can cause cavitation but I'm hoping that mine is so small and it would sit enough to the side that I wouldn't run into that issue.
The surface of the hull in front of that mounting location is smooth so I wouldn't expect any turbulence however would it be too close to the pitot?
Thoughts?
Thanks!
Thoughts?
Thanks!
