Aspera 3hp outboard info??
judostu683
Hi I have just acquired with a hutchinson nautisport a Aspera 3hp outboard was just wondering if anyone had any general info on this type of engine think its from the 70's? cant work out wether its water or air cooled? any help would be greatly appreciated cant find anything on the net:mad:.
steelespike
Re: Aspera 3hp outboard info??
If it is aircooled it will have fins on the cylinder, and fan blades on the flywheel.There will be an airshroud around the flywheel and cylinder.
If it exhausts underwater the leg will usually be water cooled.
I found a number of references to ASPERA motors.You may have
A Sea Bee with an aspera powerhead.Italian I believe.
Unfortunately not much tech info.
guzzi-cool
Hello,
I live in Holland and I have an Aspera HP3.
The outboard engine is from 1970.
I have all the drawings with exploded view and the warranty from 1970.
It still runs on fuel mixed with SAE 30 outboard oil mixed 1 to 16 !!!!!!
The users manual is in Dutch.
It also has gear oil in the what we called tail.
This is E.P. 90.
Changing you have to put the enginge on his head.
Where do you live???
Greetzz,
Tjeu
steelespike
Welcome,You will do better if you click on lionel38100 and send him a private message.
