jrs_diesel
- Mar 3, 2010
- 552
I got the pistons out of my 72 Johnson 6HP, and have some questions about them.
I had decided to pull them when I noticed some scoring on the lower piston, looking at it through the exhaust ports. After I pulled them both I noticed there was more scoring on them than initially thought.
I want to note that even though both pistons were scored, neither one of them damaged the cylinder walls in any way. On both pistons, the connecting rod and wrist pins were fine.
The upper piston had less scoring on it than the lower, which was much worse. The upper pistons damage only went from the skirt, up to the bottom ring land. The lower piston had three patches of scoring. The worst on that one went up all three rings, and the lowest ring was stuck in that one spot because of it. The stuck ring did pop out with a little effort.
Here are a couple of pictures. The first two are of the upper piston. The last three are of the lower piston.
1 - Are either of these pistons re-useable?
2 - If so, how do I clean them up?
3 - How can the pistons get scored without damaging the cylinder or ports?
