My mechanic tells me these are dry joint manifolds. When I pressed him about it he says the manifold itself is the same between the two, it's just that a dry joint manifold has a different riser and that a blocking gasket is used between the manifold and riser. I think these manifolds are old wet joint manifolds. The engine is getting rebuilt because of water intrusion into the block.
The new engine is installed, just need to put the manifolds on. But since he's taking sooo long to finish the job I just might buy new manifolds and install them myself.
