Are there only 2 grease ports on my outboard
duffg130
Hi,
I have a 1989 Johnson GT100. I’m only seeing 2 grease ports which are for the steering rod. Is that all I need to grease? Thanks
saltchuckmatt
Hi,
There should be two on the transom bracket to tilt tube. (Might be what your calling steering rod) Then there should be one on the side that greases where the motor swivels whole steering. Grease comes out the top and bottom of the midway section of the engine.
duffg130
Thanks. I found the 2 for the bracket tilt tube I’ll track down the 3rd one. I appreciate it
