are special tools required?
andrewwaddy
are special tools required to change the exhaust & driveshaft bellows on a 1987 bayliner 5.7 motors & outdrives???
Re: are special tools required?
Ayuh,.... Welcome Aboard,... Depends on What motor, 'n outdrive yer talkin' 'bout,....
Bayliner builds Boats, not motors, nor drives,...
Lou C
No special tools needed and it is possible to change them without removing the pivot housing, if it's a Cobra.
MyBad
I was just where you are, never doing this work before.
There is a ton of info on here regarding bellows replacement. Mine was a Cobra, and I did not remove the pivot housing, and it was quite easy. I even adjusted the lower shift cable, myself, the best advice I got from here was, "Get an OEM manual" "try to use OEM parts" and "make or buy a drive stand" G/L
MB
