I'm confused by sparkplug terminology.<br /><br />My local shop didn't have the Champion QL77JC4 plugs that I usually use on my 1989 Evinrude 9.9 outboard, and they cross-referenced to Autolite 2634 plugs, which I bought.<br /> <br />Then I did some web research and found cross references to both 2634 and 4093 Autolites. My main concern is that I also read that:<br /><br />"Some Johnson and Evinrude engines require a special inductive type resistor (such as Champion Q-type or NGK Z-type). Use of non-inductive resistor type plugs on these motors can cause misfire and poor performance."<br /><br />I can't find confirmation that these Autolites have this "non-inductive resistor" or not, so I talked to the shop again, and was told not to worry, that "all spark plugs have been resistor types for many years."<br /><br />My question is, are these Autolites alright for my motor, and do they have the correct resistor type, or are all resistor types the same? (Is "resistor" the same thing as "non-inductive resistor"?)<br /><br />(Edit to add motor model number CE10RCUE, and thanks in advance!)
