I went and looked at the motor today. The guy said the motor was already off the boat and ready to go so Brought my compression tester, muffs, own gas/oil mix , and a charged up battery & cables. Visually the motor looked good. Noticed discoloration on one of the heads where it may have overheated. also noticed that the head bolts looked newer and had no paint on them, possibly from rebuild. pulled the plugs, which looked normal, and installed comp tester on #1 piston and jumped the starter......starter motor turned, but the gear would not push up to engage the flywheel! Now that I'm thinking about it, I'm not so sure that I had the cables hooked up right. I hooked the negative to the block where the battery negative would be and then touched the positive jumper cable to the starter positive lug. It spun it, but the bendix wouldn't engage the flywheel. Seemed right at the time but now I'm not so sure. Anyway, I was not able to do a comp test or a run w/ muffs test at all. I did remove the bottom drain/fill plug from lower unit and loosened the top one just enough to drain some gear oil into my hand. It was not milky nor gritty. I offered him $500 for the motor and he declined. I told him $500 without the remote controls (I have two sets) and he accepted. So now I've got a motor to go through. And since my 78 runs I can take my time and do it right. I'll let you know how it goes. Thanks for all your help. This forum is great!
