Re: Arcing to engine block
When you're getting no spark on one cylinder, that is usually the power pack or ignition coil. Rare cases include a weak trigger magnet in the flywheel or a timer base. Rule out the coil first. Switch coil wires. If the problem follows the coil, replace it. If it doesnt, switch the power pack. If the problem follows, replace the power pack, or test its DVA as stated above if you have access to the meter. Unlikely but check the plug springs inside the plug boots. If they are rusty or rotted, you will get weak or no spark. If you find it highly corroded, get a new boot kit. Cut the old plug wire back, allowing enough to reach the plug, cut back a bit of the insulation, fold the exposed wires over, insert the new plug spring, spray with wd 40 to ease with installation of the boot, then slide the new boot over. Let us know what you find.
