Sam Jenkins
- Oct 16, 2020
- 49
My aq271c starts up perfectly from cold, a couple of pumps of the throttle and shes running.
If i go for a run out anchor up and go to re start 30 mins later it takes quite alot of crancking to get it fired up again. Once its fired and you turn it off and start it again it will fire right up with out any problems
Could anyone point me in the right direction of what to check to get it starting properly from hot. Good compression and timings on the mark cheers
