Aq131d
radjaz
Just tuned up the engine and it sounded like a champ. However when i put it in the water it started right up, but, sputtered and back fired with no power. Checked plug wires, distributor cap rotor. Replaced points, plugs and fluid. Can't figure it out.
JAZ
sqbtr
Re: Aq131d
Did you adjust the point dwell with a meter and then set the base timing?
radjaz
Re: Aq131d
i did initially, but, messed with the timing on the water. The distributer was adjusted fully counter clockwise, which seemed wierd.
kmarine
Re: Aq131d
Make sure the spring on the points is properly set, I have them float out at high rpm because the spring was not seated properly.
dennis461
Re: Aq131d
What else did you do before putting it in water?
Was the timing belt changed?
Did you remove and replace distributer?
radjaz
Re: Aq131d
No, couldn't find a distributer cap and was hoping to avoid changing the timing belt.
