Re: aq131a #4 exhaust valve issue? cracked head?
What do you mean it appears? Does it have a crack or not?
Have you asked the ones that made this claim that there is a problem? I haven't heard of one.
Its not a "claim", its a fact. I dont get why you need to chime in on my thread if you have no useful information to offer! I just thought I would educate you a little.....here is what someone from another forum said about this KNOWN problem that you havent heard of.
Things to watch out for: Change the manifold every 3 years regardless. The design is not that great in that the riser is built into the manifold. It lets little bits of water dangerously close to the aluminum head and will corrode it which will result in a burned out exhaust valve in the head ( ususlly #4 cyl). Timing belt and tensioner bearing. Every season, re adjust the belt tension. It is not automatic as you would think. Easy though. Just loosen the nut on the bearing and the spring will tension it for you to the proper tension. Heat exchanger, oil cooler and raw water pump. Dissassemble and clean every other season or every 2 to 3 seasons. Keep it clean. Dirty, these will slowly increase your motors opperating temps and will slowly detinate your engine. I have seen these engines dead within 400 hours of operation because of this type of neglect. Do yourself a favor and buy the pertronix ignitor kit for that distributor. Keeping the points clean and tuned is a nightmare without one.
