Aq130c-Mike
- Apr 10, 2013
- 9
I am rebuilding the entire water impeller assembly on a 1971 volvo AQ130C. I have all the parts and have removed the entire impeller pump assembly. I was careful when removing the old parts in order to ensure I put all the new parts back correctly, however, I am having trouble with the o-ring that goes between the two seals in the housing behind the water impeller since is was destroyed and fell to pieces. I have seen an expoded schematic of how the parts go, but there is approximately 1/8 of an inch between the two seals for the o-ring. I placed the o-ring right in the middle between the seals and can see it through the drain holes in the housing, but I am thinking that it must need to be flush against one of the seals....it seems that it would serve absolutely no purpose in the middle of the two seals if air (and water if one of the seals is leaking) since there is a lot of space around the o-ring in the brass housing. Hope this makes sense...it is difficult to explain. Please help...thanks, Mike
