Aq130 help on replacing thermostat
kenny nunez
Is the engine overheating? The oil cooler is easy to remove and clean, you will need new “O”rings.
If the pipes in the picture are not leaking leave them alone.
Sierra part #s for the copper pipes if you want them.
18-0606 copper pipe seals
18-3890 oil cooler seals.
18-3539 thermostat
Dannysboat
Thank you for the help on here and the part numbets are great to have all this valuable information
