ok here's the deal. the intake connection at the impeller housing leaks I have tried everything i can think of to get it to seal right.
it does have new seals
The tube must be in good shape and not bent out of shape. The bracket (#23) that holds the tube must also be in good shape and hold the tube aligned correctly
ok made sure that its got a good seal.. still no water but if i undo the hose inside and put my water hose in it the fresh water system does fine it just will not pull it form the outdrive. im going the check the hose at the out drive today and go from there.
Yep, you need good water pressure at the muffs, also plug the hole in the bottom of the drive. Pull the hose off the outdrive, under the upper ujoint bellows.
