I have just recently redone my 84 bayliner. Tried to start it today and nothing...
lets start from the beginning...
bought used and never started it.
threw out the points and condensor and installed a hot spark electronic ignition. The instructions said to hook the black wire to the negative side of the coil, and the red to the positive side of the coil.
coil did not ohm out, so bought an accel coil and installed and hooked it up the same as the old one was.
on the coil I have 3 wires, red (formerly purple to the points) to the positive. Black is on the negative along with another wire (white?). I assume that goes to the tach.
no spark at all, cap and rotor look brand new, and have new plugs....
should there be a +12v from the switch or battery hooked to the coil???
wanting this to get fixed asap!!!! want to take er out on the water...
thanks
thanks
