I have a new-to-me AQ125A which has seen the elements.
The timing belt has slipped, due to my own naivety in not running through a thorough set of checks and adjustments after purchasing; the timing belt tensioner needed adjustment.
I need to familiarize myself with the engine and the boat in the unlikely event that something breaks down when I am not at the dock. I intend to replace the timing belt and the tensioner.
Reading the forums here has really encouraged my to post and request the expert advice of this fantastic community forum before I start this job.
1. The workshop manual, step 126, states to "Place the valve cover in position without the gasket." Does this mean I need to remove the cover and scrape off the gasket?
2. The previously mentioned step also states that there is a marking on the valve cover and the pulley; I have not pulled anything off the engine yet, but have manually turned the crankshaft slowly to inspect the camshaft pulley and I do not see a marking on it or the valve cover. Could the markings be masked by the light rust on the pulley? Other than aligning the markings, is there another way to set camshaft for timing at TDC #1?
3. Finally, I suspect that the intermediate shaft timing markings will be impossible to align due to the corrosion. I believe this shaft turns the distributor rotor, as such, would it be okay to turn it so that the rotor points to the #1 spark plug wire?
