AQ125A parts help!!!
steve242002
Hey all, I have a 1982 Volvo AQ125A and i'm looking for the "bridge" that the sea pump bolts to. The bottom ear broke off and im concerned that the two existing bolts are not enough to keep the timing marks correct and im not sure if the torque generated by the sea pump will at some point break the other two off. Is there a used one anywhere out there? I've rebuilt this motor from ground up and this piece is holding me up. Any advice? I've heard that they are over 200 dollars and that just seems silly since it's just a cast part. Thanks. P.S. the part number is 828040, at least that is what the parts diagram list it as.
Robj
Re: AQ125A parts help!!!
If all else fails, try getting it welded. You can also look on ebay
Have a great day
Rob.
