aq125 engine removal lift points
ELKMCC
I got the manual but I don't see engine removal lift points. anybody know the lift points. thanks, bill
kenny nunez
Connect a chain from the rear of the exhaust manifold to the alternator belt tension bracket.
ELKMCC
Hi, thanks for that info. What do U make of this. I removed 5 of 6 bolts at rear of transom and noticed a lot of tension on last bolt. I used my GOPRO to look under motor and there is no motor mount and the motor is very easy to move around. it looks like the 6 bolts are the only thing holding the motor up. Thanks, BILL
your supposed to remove the bolts by turning each one just a bit until they are all loose. that equally unloads the donut.
