hello and thank you in advance for your help.
1985 bayliner capri 1650
AQ125B 2.1 liter 4 cylinder
I am the 2nd owner and the boat is bone stock
last summer it ran perfect and tops out about 39-40mph at 4800-5000 rpm's.
Now it barely idles and maxes out at 4200 rpms.
I had a professional marine builder rebuild the carburetor and flow test and I cleaned the contacts inside cap/rotor.
I also put in clean fresh fuel
when i add just the lightest spray of starter fluid through the mesh spark arrester, it revs up which means it's not getting enough fuel.
But the accelerator pump and jet's are clear and working well. it never hesitates when you give it gas once you get it to idle at 1800 rpm's or when running under a load.
1. Where is the best place to buy a new cap and rotor and plugs and wires and points? I can't find them on the volvo parts area of iboats.
2. does someone have a part # of a water seperater/filter from Napa that I can order online or locally?
3. is there a fuel filter in the carburetor or in line?
thank you very much for your help!!!
scott
scott
