Juneaudave
- Jun 29, 2004
- 11
You guys are great and I know you can point me in the right direction. I have an old 20ft Bayliner Explorer with a AQ131D/270 (730 hours). Last year, I took it out and it shut down after coming up on step (well, about as much step as you can get out of an Explorer). No spark...started to troubleshoot from the plugs back through the distributer and couldn't find anything...put cap back on and started right up.<br /><br />Basically..I've replaced the points, condenser, cap and rotor...set dwell and timing. It starts right up, idles well through warm up...but loses spark and shuts down at high RPMs after running. After it cools, and I fiddle around back there, it starts back up. Could this be the coil? Or is something else happening that I'm missing....Thanks, you guys have really helped alot of boaters!
