aq 125 /270 leg...exhaust pipe
gord 495
i've discouvered that my exhaust pipe that runs from below the heat exchanger to the leg is rotted out. my question is, can i replace it without having to remove the leg or engine ?<br />appreciate any help
Don S
Re: aq 125 /270 leg...exhaust pipe
You will have to remove the engine, and to remove the engine you can remove the upper gear box (Keep things clean and don't loose the shims and new orings going back together) the exhaust bellows hooks to the end of the exhaust pipe, and you might be able to get the pipe unbolted and the bellows off without removing the complete drive, but it's a LOT easier to remove the complete drive.
gord 495
so you think i'm just as well to remove the engine and complete leg assembly from the boat ? <br />because i notice that the engine only has two legs on the front of it
