I have a 2005 Mariah 3.0 SX18 bought it used found out it wont go over 3300 rpms and no power to get on plane.
Prop is Michigan wheel 14x19, 26 mph on phone app.
Read the For adults only been going through it.
Vacuum gauge reads 17"hg at 750 rpm vibrating though.
At 3300 rpm the gauge reads 2" hg also vibrating within 1/2"hg and when you observe down into the carb the fuel is fluttering around below the venturies. ODD
Replaced all fluids and filters and rebuilt carb (ran smoother but not faster)
plugs, wires and cap, adjusted timing, drained fuel tank.
compression cold was 165 on all 4 cylinders within 3 psi
I haven't done a leak down but the intake and exhaust manifold is shared and wondering if the exhaust is bleeding into the intake causing lower numbers and vibration of the needle.
