Scoop
- Jul 19, 2002
- 1,158
I love my NiMH AA batteries in all my electronics. The 2500 mAH are really nice. I went to look at D-Cells to see if I could save some money on them in the long run.
The the NiMH D-cells from Eveready are only 2500 mAH just like the AA Cells so they are not worth it. I went out on the internet and found an expensive charger and D-Cells that are 11,000 mAH. Since a regular alkaline D-cell is around 12,000 mAH, I think these should work good in high drain devices. I know they will lose charge while sitting, but this charger will trickle charge them so they are ready to go.
My question is, has anyone here used these and are they worth it. From my calculations, my break even on buying the charger and batteries vs. alkaline would be about 100 alkaline batteries. I would then have around 200 to 600 more charging cycles for free. Since my fish finder takes 8 Ds, my portable boat lights take 4 Ds, my flashlight takes 4 Ds, I think it would be worth it as long as they work ok and as long as I have an emergency set of Ds for the ones that sit in the emergency kit.
Also, the charger will charge my AAAs and AAs.
http://www.thomas-distributing.com/maha-mh-c808m-battery-charger.htm
