Anyone think this will be a valid test of the low oil alarm Merc 150 XR4.
Bumblebeeman9
I wanted to do a good test of the low oil alarm on a 1991 Mercury XR4 150. I took the oil cap off and carefully and gently put about half of a toothpick exactly the right length between the cap and the float to force the float under the cap in the full down position. Then I taped it in place with narrow tape. Then reinstalled oil cap. After the test I made sure the toothpick was still in place with the float in the full down position. With the ignition key on the alarm did not go off. Does this sound like a valid test? Does the engine have to be running for the alarm to work?
QBhoy
Hi.
never had one of these exactly but if it’s like I think it is...what tank did you jam float down on ? The oil feed tank or the tank on engine ? They do different things if I remember mine right. One will demand more oil from the feed tank and the other will sound alarm, I’m sure. Can’t quite remember. It was 20 years ago. I have a merc V6 now but yet to run it on the boat just fitted to.
I thought the tank on the motor was kept full by air pressure on oil in the main tank.
QBhoy
Might be right. It’s been a while. The one I’m thinking of has a pump in the feed tank. Possibly even thinking of an old Yamaha v4 I had. Not totally sure.
achris
More fish than mountain goat
Yes, the engine needs to be running for the alarm to sound, but you can check without such an elaborate setup. Disconnect the wires to the cap. Start the engine, alarm should sound. That proves the alarm side of the system. Next get a multimeter and check the resistance of the switch in the cap. With the cap in place and the tank full, there should be zero (or near zero) resistance. With the meter still connected, lift the cap up out of the oil. As the float drops, the resistance should go to 'infinite'... That's tests both the alarm and the float switch. Refit the cap to the oil tank and reconnect the wires.
A more important test is the 'rotation sensor'. To test that, disconnect either one of the wires running to it, and run the engine, the alarm should sound.
Chris......
