Anyone recognize this pump??
Commisatone
Pump is losing prime so I am assuming valves are done.
I would like to find repair parts but there is no name or model on it. It is a bilge pump - that much I know:) - and it's on an '89 Doral Prestancia.
Anyone have any ideas?
Fireman431
Re: Anyone recognize this pump??
For what you would pay in replacement parts for that pump---if you can find them---you could easily switch over to a standard 1100 GPH auto bilge pump with float switch.
Don S
Those are old Jabsco diaphragm pumps, not even made anymore. There used to be kits for most (not sure about that model) of their pumps, but even on a good day that pump didn't put out much water (3 gpm new). They used to be quite common, but most have been replaced. I know personally I have replaced at least 25 of them.
Commisatone
What did you replace them with? Diaphragm again or one of the common auto pumps as suggested by Fireman431?
I think I would prefer to do a straight swap out, as the wiring, separate float switch, filter, etc are already in place and I have had nothing but trouble with the auto type that have been used elsewhere on the boat - but I am looking for advice as to the route I should go.
Thanks for your time
