Anyone need Yamaha Info?
petryshyn
Gents:<br />I'm meeting with the Yamaha trainer tomorrow morning. If anyone has any technical questions on Yamaha outboards, post them and I'll try and get some answers for you. No promises, but I'll do my best.....<br /><br /> :)
letsbarbq
Re: Anyone need Yamaha Info?
Schematic,<br /><br />Its been awhile for me to check this website. I have one. I just purchased a yammy 150 around 87. i have a hard steering. I unhooked the steering cable and it pulled out and pushed in easily. But the motor was stiff. <br /><br />Please note that where the steering cable connects to the motor. That metal arm is rusted bad. I haven't taken the outboard off to inspect it but i can see it when i tilt up or down. I spray corrosion X bottle on it to prevent any further neglect.<br /><br />Can you ask the yammy guy what he think it is. What do I need to change the arm? Or is it something that i can lube up to make the enigie swing more freely. Again, it is not the cable back to the wheel. The problem is on the motor.<br /><br />Any help would be appreciated.<br /><br />letsbarbq
Trent
Common yammie problem..Remove cable and buy a steering tube brush (hone) and clean the tube up real good. Lube real good and reinstall cable.
REEL-BREAK
I just put 2 130 yamahas on my trophy 2302 and Id like to use my old tachs can I do this whats the wiring diagram color code for yamaha tachs.I do have the digital yamaha tachs. I just like the analog better.Thanks<br /> Mike
John from Madison CT
Hi Schematic,<br /><br /> Please ask the Yammie guy what would make a Digital Yammie tach. not work. Mine is hooked up properly and reads 0 RPMS and yellow for a oil reservoir level. The trim indicator works fine.<br /> It's for a 90hp 3 cyl, '89 motor.<br /><br />Thanks,<br /><br />John
prime fishing
sorry, I did not see this post until after I posted my problem. Can you look at yamaha 250 saltwater post and relay this information.
petryshyn
Sorry Guys....no magic answers....things just break<br /><br />This is as close to a diagram I could get on gauges. We couldn't get off the topic of the 200HP 4-stroke. Had her sripped down. What a work of art. Its what happens when Toyota and Yamaha work together.
