1986 OMC 3.0 with Cobra out-drive. I couldn't shift into reverse so I pulled the out-drive and I think I found the problem. This stuff looks like the corrosion you'd see on a battery terminal; very light bluish-grey. The space is full of it. The area is bone dry, the boat has only seen one salt water day in its life and my zincs are all fine. Any idea where it came from and how I can prevent a recurrence? I plan to clean it up, install new gasket set and reassemble. Anything else I should do while I'm in there? Thanks for any help!
