Anyone Have Link to Water Pump Kit/Impeller for 1997 60 HP Mariner?
Ober51
Hi,
I noticed that there was very little water coming out of my tell tale today while running my motor. I just bought the boat and motor, and this was the first time out. Rather than take the previous owner's word for it is good, I want to change out the water pump and impeller on this thing before I run it again. Can anyone link me to the correct kit/impeller? I have the engine maintenance manual and someone to help, just need to know what to buy.
Thanks!
Ober51
Re: Anyone Have Link to Water Pump Kit/Impeller for 1997 60 HP Mariner?
Forgot the identifying information:
1997 60 ELPTC
Serial: 06526576
Ober51
Maybe a part number? I found this, would this work: here or maybe this: here?
Ober51
It is 0G, I just looked again in the light. Thanks, Carholme.
Ober51
I ordered an impeller, upper water pump housing kit, and some loctite. Anything else I might need while I'm in there?
carholme
As long as you haven't noticed pools of oil above the shift shaft area or around the waterpump, indicating seal leakage, there is not much more you can do in there.
Just remember to have the LU and the boat in the same gear when you re-assemble and ensure the Reverse Lock cam is positioned correctly and that the guide is installed above it. I put a dab of grease on the guide to hold it up in the slots.
Hope all works well for you.
Gerry
Ober51
Thanks, carholme, it's very much appreciated. I hope I don't run into issues, otherwise I'd have to bring it in for service and probably lose the season.
