I have a F115RXTB. It wouldn't run above an idle. Took it to a marina to be checkout. They told me no codes and had to be the injectors plugged. I replaced the injectors. Cleaned the VST and filter, and I am still in the same problem. It idles perfect, touch the throttle it will backfire. Pump the throttle it will rev-up then fall. I am leaning towards the TPS.
