Any Recommendations? OEM Shift Box
kameika
Hi everyone.<br /><br />I have a 1988 OMC Seadrive on a Larson 226 (1989 model.) <br /><br />Currently, the boat is equipped with a "single lever" shift/throttle. My preference (by a LONG way) would be a seperate transmission and throttle controls.<br /><br />How available are "similar footprint" replacements? <br /><br />How expensive would one be? Finally, will I need to replace the throttle/transmission cables, or will they be a "one-for-one" replacement?<br /><br />Finally, do any of these have a "tilt/trim" switch integrated?<br /><br />You recommendations are appreciated!<br /><br />Ken
rodbolt
Re: Any Recommendations? OEM Shift Box
hello<br /> you can get a seperate throttle/shift box but none that use the factory omc cables. none that I have seen have trim on the handle. I reccomend you change. some tech like me really needs the money for the gear case repairs its going to create.after 20 some odd years of doing this I have found that universal controls universally dont work well. I see many gear cases torn up each year by the misadjustment and misuse of them. stick with a factory single lever and life is good.<br /> good luck and keep posting
kameika
Hmm.. I appreciate the advice. I had no idea how easy it would be to shift gears in high idle..<br /><br />Many thanks,<br />Ken
