I need to buy a new prop and I came across the opportunity to try a 13 x 17p K2 black steel Yamaha prop on my 91' 90 ho Merc. The local boat repair shop that has it said that he has found them to work really well on Mercs. Has anyone tried one before?<br /><br />He gave me a different thrust washer and a bushing that fits into the back of the hub to make it flush and told me to use my regular lock washer and nut (it has a pressed in rubber hub so I don't use my Flo-Torq II hardware). Since this bushing is flat there is now nothing for the lock washer to grab. When I asked him about that he told me not to worry about the nut coming loose because it is a nylon locking nut so it won't. Should I be concerned? Should I give this prop a try on my Merc or is there a good chance that I may loose it (since the lock washer won't really be there to keep the nut from turning)?<br /><br /> bushing installed <br /><br /> Without bushing <br /><br /> Thrust washer side of prop <br /><br /> Thrust washer
