any one have part numbers i can use
pinto 21629
i have a 1960 johnson supersea horse 40hp rds 22 seral # 2128547 i need a head gastket.head cover gasket water pump impeller.thermostat and do i need any gaskets when i change impeller for the lower unit any help i would be greatful for o and when i put the new compression relief valves in do i need any thing to make them seal or being new will they seal them selfs ????????????
pinto 21629
Re: any one have part numbers i can use
Topic: any one have part numbers i can use <br />pinto21629 <br />Seaman <br />Member # 31253 <br /><br /> posted October 07, 2005 04:28 PM <br />--------------------------------------------------------------------------------<br />i have a 1960 johnson supersea horse 40hp rds 22 seral # 2128547 i need a head gastket.head cover gasket water pump impeller.thermostat and do i need any gaskets when i change impeller for the lower unit any help i would be greatful for o and when i put the new compression relief valves in do i need any thing to make them seal or being new will they seal them selfs ????????????<br /><br />--------------------<br />pinto<br /><br />--------------------------------------------------------------------------------<br />Posts: 52 | From: maryland | Registered: Aug 2003 | IP: Logged |
muskrat
HD GASKET#307069<br />WATER JACKET GASKET#305205<br />IMPELLER#777213<br />THERMO#5005440<br />THERMO HSG GASKET#305196<br />THERM GASKET#305198<br />GOOD LUCK
